inria-00390465, version 1
Optimization of complex robot applications under real physical limitations
Matthieu Guilbert
1, 2Pierre-Brice Wieber
a, 2Luc Joly
1
International Journal of Robotics Research 27, 5 (2008) 629-644
Résumé : This paper deals with minimum time tra jectory optimization along a specified path sub ject to thermal constraints. We point out here that robots are often integrated in complex robotic cells, and the interactions between the robot and its environment are often difficult or even impossible to model. The structure of the optimization problem allows us to decompose the optimization in two levels, the first one being based on models and results of the theory of the calculus of variations, the second one being based on measurements and derivative free algorithms. This decomposition allows us to optimize the velocity profiles efficiently without knowing in advance the interactions between the robot and is environment. We propose here two numerical algorithms for these two levels of the decomposition which show good convergence properties. The resulting optimal velocity profiles are 5 to 10% faster than classical ones, and have been executed on successfully on a real St¨aubli Rx90 manipulator robot.
- a – INRIA
- 1 : Staubli R&D Robotique SCA (STAUBLI)
- STAUBLI
- 2 : BIPOP (INRIA Grenoble Rhône-Alpes / LJK Laboratoire Jean Kuntzmann)
- INRIA – Laboratoire Jean Kuntzmann
- Domaine : Informatique/Robotique
Mathématiques/Optimisation et contrôle
- inria-00390465, version 1
- http://hal.inria.fr/inria-00390465
- oai:hal.inria.fr:inria-00390465
- Contributeur : Pierre-Brice Wieber
- Soumis le : Mardi 2 Juin 2009, 11:19:55
- Dernière modification le : Vendredi 12 Juin 2009, 14:16:23
Documents associés
Exporter
