s'authentifier
version française rss feed
inria-00390485, version 1
Modular Architecture for Humanoid Walking Pattern Prototyping and Experiments
Olivier Stasse 1, Bjorn Verrelst 2, Pierre-Brice Wieber () a3, Bram Vanderborght 2, Paul Evrard 1, Abderrahmane Kheddar 1, Kazuhito Yokoi 1
Advanced Robotics 22 (2008) 589-611
Résumé : In this paper we describe the use of design patterns as a basis for creating humanoid walking pattern generator software having a modular architecture. This architecture enabled the rapid porting of several novel walking algorithms on a full-size humanoid robot, HRP-2. The body of work currently available allows extracting a general software architecture usable with inter-exchange between simulations and real experiments. The proposed architecture with the associated design patterns is described together with several applications: a pattern generator for a HRP-2 with passive toe joints, a pattern for dynamically stepping over large obstacles and a new quadratic problem (QP) formulation for the generation of the reference zero-momentum point. Thanks to the versatility and the modularity of the proposed framework, the QP method has been implemented and experienced within 4 days only.
  • Domaine : Informatique/Robotique
  • inria-00390485, version 1
  • oai:hal.inria.fr:inria-00390485
  • Contributeur :
  • Soumis le : Mardi 2 Juin 2009, 14:16:57
  • Dernière modification le : Vendredi 12 Juin 2009, 14:10:20
tous les articles de la base du CCSd...
