s'authentifier
version française rss feed
inria-00392581, version 2
Towards an efficient process placement policy for MPI applications in multicore environments
Guillaume Mercier (Auteur à contacter de préférence) a123, Jérôme Clet-Ortega b12
Europvm/mpi 2009 5759 (2009) pp 104--115
Résumé : This paper presents a method to efficiently place MPI processes on multicore machines. Since MPI implementations often feature efficient supports for both shared-memory and network communication, an adequate placement policy is a crucial step to improve applications performance. As a case study, we show the results obtained for several NAS computing kernels and explain how the policy influences overall performance. In particular, we found out that a policy merely increasing the intranode communication ratio is not enough and that cache utilization is also an influential factor. A more sophisticated policy (eg. one taking into account the architecture's memory structure) is required to observe performance improvements.
  • Domaine : Informatique/Calcul parallèle, distribué et partagé
  • Mots-clés : MPI - Multicore - Process Placement
  • Versions disponibles :  v1 (08-06-2009) v2 (26-11-2009)
  • inria-00392581, version 2
  • oai:hal.inria.fr:inria-00392581
  • Contributeur :
  • Soumis le : Jeudi 26 Novembre 2009, 10:50:44
  • Dernière modification le : Jeudi 26 Novembre 2009, 17:52:46
tous les articles de la base du CCSd...
