Virtualization of Service Gateways in Multi-provider Environments - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Communication Dans Un Congrès Année : 2006
Yvan Royon
  • Fonction : Auteur
  • PersonId : 840738
Stéphane Frénot
Today we see more and more services being brought to connected homes, such as entertainment or home automation. These services are published and operated by a variety of service providers. Currently, each provider sells his own box, providing both connectivity and a closed service environment. The open service paradigm aims at mixing all services within the same box, thus opening the service delivery chain for home users. However, open service gateways still lack important mechanisms. Multiple service providers can access and use the same gateway concurrently. We must define what this use is, i.e. we must define a notion of user. Also, service providers should not interfere with each other on the gateway, except if explicitly required. In other words, we must isolate services from different providers, while still permitting on-demand collaboration. By combining all these mechanisms, we are defining a multi-user, multiservice execution environment, which we call a virtualized service gateway. We implement part of these features using OSGi technology.
CBSE2006.pdf (367.64 Ko) Télécharger le fichier
inria-00394956 , version 1 (12-06-2009)
Yvan Royon, Stéphane Frénot, Frédéric Le Mouël. Virtualization of Service Gateways in Multi-provider Environments. Proceedings of the 9th International SIGSOFT Symposium on Component-Based Software Engineering (CBSE'2006), Jun 2006, Västeraas, Sweden. pp.385-392, ⟨10.1007/11783565_31⟩. ⟨inria-00394956⟩
138 Consultations
170 Téléchargements
