Dynamic Observers for the Synthesis of Opaque Systems - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Communication Dans Un Congrès Année : 2009
In this paper, we address the problem of synthesizing opaque systems. A secret predicate S over the runs of a system G is opaque to an external user having partial observability over G, if s/he can never infer from the observation of a run of G that the run belongs to S. We first investigate the case of static partial observability where the set of events the user can observe is fixed a priori. In this context, we show that checking whether a system is opaque is PSPACE-complete, which implies that computing an optimal static observer ensuring opacity is also a PSPACE-complete problem. Next, we introduce dynamic partial observability where the set of events the user can observe changes over time. We show how to check that a system is opaque w.r.t. to a dynamic observer and also address the corresponding synthesis problem: given a system G and secret states S, compute the set of dynamic observers under which S is opaque. Our main result is that the set of such observers can be finitely represented and can be computed in EXPTIME.
atva-final.pdf (168.96 Ko) Télécharger le fichier
inria-00399229 , version 1 (16-10-2009)
Franck Cassez, Jérémy Dubreil, Hervé Marchand. Dynamic Observers for the Synthesis of Opaque Systems. 7th International Symposium on Automated Technology for Verification and Analysis (ATVA'09), Oct 2009, Macao SAR, China. pp.352-367, ⟨10.1007/978-3-642-04761-9_26⟩. ⟨inria-00399229⟩
190 Consultations
74 Téléchargements
