Real-time realistic illumination and shading of stratiform clouds - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Communication Dans Un Congrès Année : 2006
Realistic rendering of clouds involves solving the complex interaction of light within the cloud and with its environment. Interactive methods achieve efficient cloud rendering by ignoring several lighting effects. However, these effects are visually important, and removing them strongly reduces realism. We present a novel approach for capturing the important effects of multiple anisotropic Mie scattering within cloud layers (i.e., stratiform clouds), and the inter-reflections between the ground and the cloud base under sun and sky illumination. Our model maps well to graphics hardware, enabling the real-time rendering of animated cloud skies over landscapes.
bnl06-elec.pdf (5.97 Mo) Télécharger le fichier
BNL06.ppt (9.87 Mo) Télécharger le fichier
clouds.avi (18.33 Mo) Télécharger le fichier
clouds0.avi (8.45 Mo) Télécharger le fichier
Format : Figure, Image
Format : Autre
Format : Vidéo
Format : Vidéo
inria-00402100 , version 1 (20-05-2011)
  • HAL Id : inria-00402100 , version 1
Antoine Bouthors, Fabrice Neyret, Sylvain Lefebvre. Real-time realistic illumination and shading of stratiform clouds. Eurographics Workshop on Natural Phenomena, Eurographics, Sep 2006, Vienne, Austria. ⟨inria-00402100⟩
3434 Consultations
1803 Téléchargements
