Simulation of Smoke Based on Vortex Filament Primitives - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Communication Dans Un Congrès Année : 2005
We describe a method that permits the high performance simulation of fluid phenomena such as smoke, with high-level control for the artist. Our key primitives are vortex filament and vortex ring: vorticity defines a flow as well as velocity does, and for numerous interesting flows such as smoke or explosions this information is very compact and tightly linked to the visual features of the fluid. We treat these vortices as 1D Lagrangian primitives (i.e. connected particles), which permit unbounded fluids and very accurate positioning of the features. The simulation of passive density particles for rendering is totally independent of the fluid animation itself. Thus, the animation can be efficiently simulated, edited and even stored, while the fluid resolution used for rendering can be arbitrarily high. We aim at plausible fluids rather than physical accuracy. For efficiency and stability, we introduce a new formalization of the Biot-Savart law and a modified Biot-Savart kernel. Our model also introduces a hierarchical filament structure for animation LOD, turbulent noise, and an original scheme for density particles.
paper0132.pdf (1.33 Mo) Télécharger le fichier
SCA05.ppt (2.16 Mo) Télécharger le fichier
VortexFilaments.avi (23.28 Mo) Télécharger le fichier
Format : Figure, Image
Format : Autre
Format : Vidéo
inria-00402131 , version 1 (23-05-2011)
Alexis Angelidis, Fabrice Neyret. Simulation of Smoke Based on Vortex Filament Primitives. Symposium on Computer Animation (SCA '05), ACM-SIGGRAPH/EG, Jul 2005, Los Angeles, United States. pp.35-48, ⟨10.1145/1073368.1073380⟩. ⟨inria-00402131⟩
482 Consultations
532 Téléchargements
