FDTD Based Seismic Modeling and Reverse Time Migration on a GPU Cluster - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Communication Dans Un Congrès Année : 2009
We have designed a fast parallel simulator that solves the acoustic wave equation on a GPU cluster. Solving the acoustic wave equation in an oil exploration industrial context aims at speeding up seismic modeling and Reverse Time Migration. We use a finite difference approach on a regular mesh, in both 2D and 3D cases. The acoustic wave equation is solved in either a constant density or a variable density domain. We use CUDA to take advantage of the GPUs computational power. We study different implementations and their impact on the application performance. We obtain a speedup of 11 for Reverse Time Migration and up to 30 for the modeling application over a sequential code running on general purpose CPU.
waves09.pdf (71.12 Ko) Télécharger le fichier
inria-00407782 , version 1 (28-07-2009)
  • HAL Id : inria-00407782 , version 1
Rached Abdelkhalek, Henri Calandra, Olivier Coulaud, Guillaume Latu, Jean Roman. FDTD Based Seismic Modeling and Reverse Time Migration on a GPU Cluster. 9th International Conference on Mathematical and Numerical Aspects of Waves Propagation - Waves 2009, 2009, Pau, France. ⟨inria-00407782⟩
417 Consultations
363 Téléchargements
