Asymptotics of Canonical and Saturated RNA Secondary Structures - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Journal of Bioinformatics and Computational Biology Année : 2009
Peter Clote
  • Fonction : Auteur
  • PersonId : 862805
Evangelos Kranakis
Bruno Salvy
Connectez-vous pour contacter l'auteur
It is a classical result of Stein and Waterman that the asymptotic number of RNA secondary structures is $1.104366 n^{-3/2} 2.618034^n$. In this paper, we study combinatorial asymptotics for two special subclasses of RNA secondary structures - canonical and saturated structures. Canonical secondary structures were introduced by Bompfünewerer et al., who noted that the run time of Vienna RNA Package is substantially reduced when restricting computations to canonical structures. Here we provide an explanation for the speed-up. Saturated secondary structures have the property that no base pairs can be added without violating the definition of secondary structure (i.e. introducing a pseudoknot or base triple). Here we compute the asymptotic number of saturated structures, we show that the asymptotic expected number of base pairs is $0.337361 n$, and the asymptotic number of saturated stem-loop structures is $0.323954 1.69562^n$, in contrast to the number $2^{n-2}$ of (arbitrary) stem-loop structures as classically computed by Stein and Waterman. Finally, we show that the density of states for [all resp. canonical resp. saturated] secondary structures is asymptotically Gaussian. We introduce a stochastic greedy method to sample random saturated structures, called quasi-random saturated structures, and show that the expected number of base pairs of is $0.340633 n$.
paper.pdf (328.27 Ko) Télécharger le fichier
inria-00411277 , version 1 (27-08-2009)
  • HAL Id : inria-00411277 , version 1
  • ARXIV : 0908.4003
Peter Clote, Evangelos Kranakis, Danny Krizanc, Bruno Salvy. Asymptotics of Canonical and Saturated RNA Secondary Structures. Journal of Bioinformatics and Computational Biology, 2009, 22 p. ⟨inria-00411277⟩
Collections
INRIA INRIA2
55 Consultations
121 Téléchargements
