s'authentifier
version française rss feed
inria-00413159, version 1
An Algorithm for Constructing the Convex Hull of a Set of Spheres in Dimension d
Jean-Daniel Boissonnat () 1, André Cerezo a1, Olivier Devillers () 1, Jacqueline Duquesne 1, Mariette Yvinec () 12
Computational Geometry 6 (1996) 123-130
Résumé : We present an algorithm which computes the convex hull of a set of spheres in dimension d in time O(n^ceil(d/2)+n log n). It is worst case optimal in three dimensions and in even dimensions. The same method can also be used to compute the convex hull of a set of n homethetic objects of Ed. If the complexity of each object is constant, the time needed in the worst case is O(n^ceil(d/2)+n log n).
  • Domaine : Informatique/Géométrie algorithmique
  • inria-00413159, version 1
  • oai:hal.inria.fr:inria-00413159
  • Contributeur :
  • Soumis le : Jeudi 3 Septembre 2009, 14:15:56
  • Dernière modification le : Mardi 20 Octobre 2009, 10:35:46
tous les articles de la base du CCSd...
