An Event-Based Coordination Model for Context-Aware Applications - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Communication Dans Un Congrès Année : 2008
Context-aware applications adapt their behavior depending on changes in their environment context. Programming such applications in a modular way requires to modularize the global context into more specific contexts and attach specific behavior to these contexts. This is reminiscent of aspects and has led to the notion of context-aware aspects. This paper revisits this notion of context-aware aspects in the light of previous work on concurrent event-based aspect-oriented programming (CEAOP). It shows how CEAOP can be extended in a seamless way in order to define a model for the coordination of concurrent adaptation rules with explicit contexts. This makes it possible to reason about the compositions of such rules. The model is concretized into a prototypical modeling language.
nunez-noye-coordination08.pdf (260.06 Ko) Télécharger le fichier
inria-00414652 , version 1 (09-09-2009)
Angel Núñez, Jacques Noyé. An Event-Based Coordination Model for Context-Aware Applications. 10th International Conference on Coordination Models and Languages (COORDINATION 2008), Jun 2008, Oslo, Norway. pp.232-248, ⟨10.1007/978-3-540-68265-3_15⟩. ⟨inria-00414652⟩
98 Consultations
127 Téléchargements
