AdHocFS: Sharing Files in WLANs - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Communication Dans Un Congrès Année : 2003
This paper presents the ADHOCFS file system for mobile users, which realizes transparent, adaptive file access according to the users' specific situations (e.g., device in use, network connectivity, etc). The paper concentrates more specifically on the support of ADHOCFS for collaborative file sharing within ad hoc groups of trusted nodes that are in the local communication of each other using the underlying ad hoc network, which has not been addressed in the past.
BoulkenafedI03a.pdf (188.87 Ko) Télécharger le fichier
inria-00414797 , version 1 (10-09-2009)
  • HAL Id : inria-00414797 , version 1
Malika Boulkenafed, Valérie Issarny. AdHocFS: Sharing Files in WLANs. 2nd IEEE International Symposium on Network Computing and Applications : NCA 2003, 2003, Cambridge, MA, United States. pp.156. ⟨inria-00414797⟩
Collections
INRIA INRIA2
104 Consultations
172 Téléchargements
