Efficient Combination of Confidence Measures for Machine Translation - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Communication Dans Un Congrès Année : 2009
We present in this paper a twofold contribution to Confidence Measures for Machine Translation. First, in order to train and test confidence measures, we present a method to automatically build corpora containing realistic errors. Errors introduced into reference translation simulate classical machine translation errors (word deletion and word substitution), and are supervised by Wordnet. Second, we use SVM to combine original and classical confidence measures both at word- and sentence-level. We show that the obtained combination outperforms by 14% (absolute) our best single word-level confidence measure, and that combination of sentence-level confidence measures produces meaningful scores.
interspeech09.pdf (76.35 Ko) Télécharger le fichier
inria-00417546 , version 1 (16-09-2009)
  • HAL Id : inria-00417546 , version 1
Sylvain Raybaud, David Langlois, Kamel Smaïli. Efficient Combination of Confidence Measures for Machine Translation. 10th Annual Conference of the International Speech Communication Association - INTERSPEECH 2009, Sep 2009, Brighton, United Kingdom. ⟨inria-00417546⟩
88 Consultations
124 Téléchargements
