Image fusion and catheter robotics for EP procedures - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Document Associé À Des Manifestations Scientifiques Année : 2009
Atrial fibrillation (AF) is a supraventricular tachyarrhythmia characterized by uncoordinated atrial activation with associated deterioration of atrial mechanical function. It is the most common cardiac arrhythmia, becomes more prevalent with age, and is associated with an increased long-term risk of stroke, heart failure and all-cause mortality. It is likely that most AF occurs primarily in the context of an interplay between left atrial electrical and mechanical dysfunction and later becomes selfperpetuating by promoting further electromechanical change during ongoing fibrillation.
1_3_oneill.pdf (116.04 Ko) Télécharger le fichier
inria-00418476 , version 1 (18-09-2009)
  • HAL Id : inria-00418476 , version 1
Mark O'Neill. Image fusion and catheter robotics for EP procedures. CI2BM09 - MICCAI Workshop on Cardiovascular Interventional Imaging and Biophysical Modelling, Sep 2009, London, United Kingdom. 2 p. ⟨inria-00418476⟩
Collections
CI2BM09
17 Consultations
12 Téléchargements
