Distributed Planetary Object Name Service: Issues and Design Principles - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Rapport (Rapport De Recherche) Année : 2009
The ONS is a central lookup service used in the EPCglobal network for retrieving the location of information about a specific EPC. This centralized solution lacks scalability and fault tolerance. We present the design principles of a distributed solution for ONS lookup service. In distributed systems, the problem of providing a scalable location service requires a dynamic mechanism to associate identification and location. We show that the use of Distributed Hash Tables (DHT) is a good candidate for distributing as it provides such a mechanism. We then outline how to adapt the DHT principles (operations on objects or nodes) to the ONS distribution problem.
RR-7042.pdf (653.39 Ko) Télécharger le fichier
inria-00419496 , version 1 (24-09-2009)
  • HAL Id : inria-00419496 , version 1
Marcelo Dias de Amorim, Serge Fdida, Nathalie Mitton, Loïc Schmidt, David Simplot-Ryl. Distributed Planetary Object Name Service: Issues and Design Principles. [Research Report] RR-7042, INRIA. 2009. ⟨inria-00419496⟩
231 Consultations
215 Téléchargements
