Improving Integral Cryptanalysis against Rijndael with Large Blocks - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Rapport (Rapport De Recherche) Année : 2009
This report presents new four-round integral properties against the Rijndael cipher with block sizes larger than 128 bits. Using higher-order multiset distinguishers and other well-known extensions of those properties, the deduced attacks reach up to 7 and 8 rounds of Rijndael variants with 160 up to 256-bit blocks. For example, a 7-rounds attack against Rijndael-224 has a time complexity equal to $2^{80}$.
squelette-rr.pdf (210.59 Ko) Télécharger le fichier
inria-00423681 , version 1 (12-10-2009)
  • HAL Id : inria-00423681 , version 1
  • ARXIV : 0910.2153
Marine Minier, Benjamin Pousse. Improving Integral Cryptanalysis against Rijndael with Large Blocks. [Research Report] 2009. ⟨inria-00423681⟩
171 Consultations
137 Téléchargements
