A Categorical Semantics for The Parallel Lambda-Calculus - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Rapport (Rapport De Recherche) Année : 2009
In this report, we define a sound and complete categorical semantics for the parallel lambda-calculus, based on a notion of aggregation monad which is modular w.r.t. associativity, commutativity and idempotence. To prove completeness, we introduce a category of partial equivalence relations adapted to parallelism, in which any extension of the basic equational theory of the calculus is induced by some model. We also present abstract methods to construct models of the parallel lambda-calculus in categories where particular equations have solutions, such as the category of Scott domains and its variants, and check that G. Boudol's original semantics is a particular case of ours.
RR-7063.pdf (253.5 Ko) Télécharger le fichier
inria-00424248 , version 1 (14-10-2009)
  • HAL Id : inria-00424248 , version 1
Germain Faure, Alexandre Miquel. A Categorical Semantics for The Parallel Lambda-Calculus. [Research Report] RR-7063, INRIA. 2009, pp.22. ⟨inria-00424248⟩
286 Consultations
142 Téléchargements
