Stabilization of switched linear systems: a sliding mode approach - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Communication Dans Un Congrès Année : 2009
In this paper, the existence of stabilizing sliding motions in the context of switched linear systems is investigated. We consider the case of switched systems with two subsystems and we propose conditions for the existence of stable sliding hyper-planes. For particular cases of switched systems (planar systems, integrator chains), we provide constructive analytical methods for deriving a stabilizing switching sequence.
Automatique
ADHS09.pdf (252.29 Ko) Télécharger le fichier
inria-00424438 , version 1 (15-10-2009)
Thierry Floquet, Laurentiu Hetel, Wilfrid Perruquetti. Stabilization of switched linear systems: a sliding mode approach. ADHS'09 - IFAC Conference on Analysis and Design of Hybrid Systems, Sep 2009, Saragosse, Spain. ⟨10.3182/20090916-3-ES-3003.00063⟩. ⟨inria-00424438⟩
142 Consultations
225 Téléchargements
