A new control strategy for shape memory alloys actuators - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Communication Dans Un Congrès Année : 2009
Shape memory alloys (SMA) are more and more integrated in engineering applications. These materials with their shape memory effect permit to simplify mechanism and to reduce the size of actuators. SMA parts can easily be activated by Joule effect but their modelling and consequently their control remains difficult, it is principally due to their hysteretic thermomechanical behaviour. Another difficulty is that the characteristics of the material are time-varying, especially during cyclic loadings. So, most of successful control strategy applied to SMA actuator are particularly heavy and used the Preisach model or neural networks to model the hysteretic behaviour of these material but this kind of models are difficult to identify and to use in real time. That is why this study deals with an application of the new framework of model-free control and restricted model control applied to a SMA spring based actuator. This control strategy is based on new results on fast derivative s estimation of noisy signals, its main advantages are: its simplicity, its robustness and the fact that it is easy to compute. Experimental results and comparisons with PID control are exposed that demonstrate the efficiency of this new control strategy despite thermal perturbations.
Automatique
paper_esomat_2009_new_control_strategy_SMA_Actuators.pdf (386.63 Ko) Télécharger le fichier
inria-00424933 , version 1 (19-10-2009)
inria-00424933 , version 2 (22-10-2009)
  • HAL Id : inria-00424933 , version 2
Pierre-Antoine Gédouin, Cédric Join, Emmanuel Delaleau, Jean-Matthieu Bourgeot, Shabnam Arbab-Chirani, et al.. A new control strategy for shape memory alloys actuators. 8th European Symposium on Martensitic Transformations, Sep 2009, Prague, Czech Republic. pp.CDROM. ⟨inria-00424933v2⟩
401 Consultations
399 Téléchargements
