Implementing Protein Seed-Based Comparison Algorithm on the SGI RASC-100 Platform - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Communication Dans Un Congrès Année : 2009
This paper describes a parallel FPGA implementation of a genomic sequence comparison algorithm for finding similarities between a large set of protein sequences and full genomes. Results comparable to the tblastn program from the BLAST family are provided while the computation is improved by a factor 19. The performances are mainly due to the parallelization of a critical code section on the SGI RASC-100 accelerator.
raw_2009.pdf (389.54 Ko) Télécharger le fichier
inria-00425237 , version 1 (20-10-2009)
  • HAL Id : inria-00425237 , version 1
van Hoa Nguyen, Alexandre Cornu, Dominique Lavenier. Implementing Protein Seed-Based Comparison Algorithm on the SGI RASC-100 Platform. Reconfigurable Architectures Workshop - IPDPS, May 2009, Rome, Italy. ⟨inria-00425237⟩
222 Consultations
154 Téléchargements
