The Voronoi diagram of three arbitrary lines in R3 - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Communication Dans Un Congrès Année : 2009
In this paper we study the Voronoi diagram of lines in R3 . The Voronoi diagram of three lines in general position was studied in [8]. In this paper we complete this work by presenting a complete characterization of the Voronoi diagram of three arbitrary lines in R3 . As in the general case, we prove that the arcs of trisectors are always monotonic in some direction and we show how to separate the connected components and to sort points along each arc of a trisector using only rational linear semi-algebraic tests. These results are important for the robust computation of the Voronoi diagram of polyhedra.
EuroCG09.pdf (136.18 Ko) Télécharger le fichier
inria-00425378 , version 1 (21-10-2009)
  • HAL Id : inria-00425378 , version 1
Hazel Everett, Christian Gillot, Daniel Lazard, Sylvain Lazard, Marc Pouget. The Voronoi diagram of three arbitrary lines in R3. 25th European Workshop on Computational Geometry - EuroCG'09, Mar 2009, Bruxelles, Belgium. pp.297-300. ⟨inria-00425378⟩
298 Consultations
213 Téléchargements
