Experimentations With CoRDAGe, A Generic Service For Co-Deploying and Re-Deploying Applications On Grids - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Rapport (Rapport De Recherche) Année : 2009
Computer grids are made of thousands of heterogeneous physical resources that belong to different administration domains. This makes the use of the grid very complex. In this paper, we focus on deploying distributed applications at a large scale. As the application requirements may often not be anticipated, dynamic re-deployment is needed; if various applications have to co-operate within a workflow, they should also be co-deployed in a consistent way. In a previous paper, we have described the CORDAGE deployment model and its architecture. It meets the three properties of transparency, versatility, and neutrality. We report in this paper on its application to a real co-deployment over the GRID'5000 experimental platform, using different configurations, including multiple clients, multiple applications and multiple grid sites.
RR-7086.pdf (167.66 Ko) Télécharger le fichier
inria-00425555 , version 1 (22-10-2009)
inria-00425555 , version 2 (05-11-2009)
inria-00425555 , version 3 (05-11-2009)
  • HAL Id : inria-00425555 , version 3
Loïc Cudennec, Gabriel Antoniu, Luc Bougé. Experimentations With CoRDAGe, A Generic Service For Co-Deploying and Re-Deploying Applications On Grids. [Research Report] RR-7086, INRIA. 2009, pp.14. ⟨inria-00425555v3⟩
217 Consultations
153 Téléchargements
