Computing Direct Shadows Cast by Convex Polyhedra - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Communication Dans Un Congrès Année : 2009
We present an exact method to compute the boundaries between umbra, penumbra and full-light regions cast on a plane by a set of disjoint convex polyhedra, some of which are light sources. This method builds on a recent characterization of topological visual event surfaces presented in a companion paper.
Shadows-abstract.pdf (1.07 Mo) Télécharger le fichier
inria-00431544 , version 1 (12-11-2009)
  • HAL Id : inria-00431544 , version 1
Julien Demouth, Xavier Goaoc. Computing Direct Shadows Cast by Convex Polyhedra. 25th European Workshop on Computational Geometry - EuroCG 2009, Mar 2009, Brussels, Belgium. ⟨inria-00431544⟩
245 Consultations
227 Téléchargements
