Undo in Peer-to-peer Semantic Wikis - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Communication Dans Un Congrès Année : 2009
Charbel Rahhal
  • Fonction : Auteur
  • PersonId : 842038
Stéphane Weiss
  • Fonction : Auteur
  • PersonId : 858590
Hala Skaf-Molli
Pascal Urso
  • Fonction : Auteur
  • PersonId : 830668
Pascal Molli
The undo mechanism is an essential feature in collaborative editing systems. Most popular semantic wikis support a revert feature, some provide an undo feature to remove any modication at any time. However this undo feature does not always succeed. Supporting the undo mechanism for P2P semantic wikis has never been tackled. In this paper, we present an undo approach for Swooki the rst P2P semantic wiki. We identify the problems to resolve in order to achieve such mechanism for P2P semantic wikis.We give the denition of the undo and the properties that must ensure. This approach allows both a revert and a permanent successful undo.
SemWiki09.pdf (385.59 Ko) Télécharger le fichier
inria-00432212 , version 1 (14-11-2009)
  • HAL Id : inria-00432212 , version 1
Charbel Rahhal, Stéphane Weiss, Hala Skaf-Molli, Pascal Urso, Pascal Molli. Undo in Peer-to-peer Semantic Wikis. SemWiki' 2009 - 4rd Semantic Wiki Workshop at the 6th European Semantic Web Conference - ESWC 2009, Jul 2009, Heraklion, Greece. ⟨inria-00432212⟩
237 Consultations
645 Téléchargements
