s'authentifier
version française rss feed
inria-00433036, version 3
High resolution SAR-image classification
Vladimir Krylov () 12, Josiane Zerubia () 1
N° RR-7108 (2009)
Résumé : In this report we propose a novel classification algorithm for high and very high resolution synthetic aperture radar (SAR) amplitude images that combines the Markov random field approach to Bayesian image classification and a finite mixture technique for probability density function estimation. The finite mixture modeling is done by dictionary-based stochastic expectation maximization amplitude histogram estimation approach. The developed semiautomatic algorithm is extended to an important case of multi-polarized SAR by modeling the joint distributions of channels via copulas. The accuracy of the proposed algorithm is validated for the application of wet soil classification on several high resolution SAR images acquired by TerraSAR-X and COSMO-SkyMed.
  • Domaine : Sciences cognitives/Informatique
    Informatique/Traitement des images
  • Mots-clés : SAR classification – dictionary-based stochastic expectation maximization – copulas – Markov random fields
  • Référence interne : RR-7108
  • Versions disponibles :  v1 (11-12-2009) v2 (13-12-2009) v3 (18-01-2010)
  • inria-00433036, version 3
  • oai:hal.inria.fr:inria-00433036
  • Contributeur :
  • Soumis le : Lundi 18 Janvier 2010, 13:26:37
  • Dernière modification le : Lundi 18 Janvier 2010, 14:21:14
tous les articles de la base du CCSd...
