Vertex Removal in Two Dimensional Delaunay Triangulation: Asymptotic Complexity is Pointless - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Rapport (Rapport De Recherche) Année : 2009
Olivier Devillers
The theoretical complexity of vertex removal in a Delaunay triangulation is often given in terms of the degree d of the removed point with usual results O(d), O(d log d), or O(d²). In fact the asymptotic complexity is of poor interest since d is usually quite small. In this paper we carefully design code for small degrees 3 ≤ d ≤ 7, it improves the global behavior of the removal for random points by a factor of 2.
RR-7104.pdf (491.69 Ko) Télécharger le fichier
inria-00433107 , version 1 (18-11-2009)
  • HAL Id : inria-00433107 , version 1
Olivier Devillers. Vertex Removal in Two Dimensional Delaunay Triangulation: Asymptotic Complexity is Pointless. [Research Report] RR-7104, INRIA. 2009, pp.15. ⟨inria-00433107⟩
373 Consultations
218 Téléchargements
