Améliorer la conception des applications interactives par l'utilisation conjointe du modèle PAC et des patrons de conception - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Communication Dans Un Congrès Année : 2006
Software architectural models like MVC and PAC are now well known, and can be implemented in many different ways. This is a problem for students when they have to implement these models, because they do not know how to select an appropriate solution. For now several years we have proposed a methodology to facilitate the implementation of the PAC model. This methodology is mainly based on Design Patterns such as « Proxy », « Abstract Factory », and « Singleton ». Thanks to this methodology, the structure of the source code is imposed and ensures an efficient separation between the application kernel and the GUI. Then, students learn to implement this separation efficiently, and they discover also with this separation that the software can evolve more easily: it is easy to change the GUI or the kernel without affecting the other part, and to add interaction possibilities to a non-interactive kernel.
article_JCT_TD_version_finale_definitive.pdf (165.49 Ko) Télécharger le fichier
inria-00433839 , version 1 (21-11-2009)
Thierry Duval, Jean-Claude Tarby. Améliorer la conception des applications interactives par l'utilisation conjointe du modèle PAC et des patrons de conception. IHM 2006, AFIHM - ACM, Apr 2006, Montréal, Canada. pp.225-232, ⟨10.1145/1132736.1132773⟩. ⟨inria-00433839⟩
172 Consultations
351 Téléchargements
