From Self-Interpreters to Normalization by Evaluation - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Communication Dans Un Congrès Année : 2009
We characterize normalization by evaluation as the composition of a self-interpreter with a self-reducer using a special representation scheme, in the sense of Mogensen (1992). We do so by deriving in a systematic way an untyped normalization by evaluation algorithm from a standard interpreter for the λ-calculus. The derived algorithm is not novel and indeed other published algorithms may be obtained in the same manner through appropriate adaptations to the representation scheme.
selfnbe.pdf (62.05 Ko) Télécharger le fichier
inria-00434284 , version 1 (21-11-2009)
  • HAL Id : inria-00434284 , version 1
  • ARXIV : 0911.4203
Mathieu Boespflug. From Self-Interpreters to Normalization by Evaluation. 2009 Workshop on Normalization by Evaluation, Olivier Danvy, Aug 2009, Los Angeles, United States. ⟨inria-00434284⟩
70 Consultations
103 Téléchargements
