R-IAC : Robust Intrinsically Motivated Active Learning - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Communication Dans Un Congrès Année : 2009
IAC was initially introduced as a developmental mechanisms allowing a robot to self-organize developmental trajectories of increasing complexity without pre-programming the particular developmental stages. In this paper, we argue that IAC and other intrinsically motivated learning heuristics could be viewed as active learning algorithms that are particularly suited for learning forward models in unprepared sensorimotor spaces with large unlearnable subspaces. Then, we introduce a novel formulation of IAC, called R-IAC, and show that its performances as an intrinsically motivated active learning algorithm are far superior to IAC in a complex sensorimotor space where only a small subspace is neither unlearnable nor trivial. We also show results in which the learnt forward model is reused in a control scheme.
BaranesOudeyerICDL09.pdf (896.33 Ko) Télécharger le fichier
inria-00438595 , version 1 (04-12-2009)
  • HAL Id : inria-00438595 , version 1
Adrien Baranes, Pierre-Yves Oudeyer. R-IAC : Robust Intrinsically Motivated Active Learning. International Conference on Development and Learning 2009, Jun 2009, Shanghai, China. ⟨inria-00438595⟩
59 Consultations
161 Téléchargements
