Assessing Inductive Logic Programming Classification Quality by Image Synthesis - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Communication Dans Un Congrès Année : 2009
One of the major difficulties in classification is the assessment of classification quality. This paper builds on a recently developed classification technique, based on Inductive Logic Programming to propose a way of visually reconstructing the learnt classes in order to give a feedback to the user. The system translates positioning constraints into a linear programming problem, which can be solved with standard state-of-the- art approaches. The result can then be used for generating a synthetic image, representative of the class.
Lamiroy_Final_ILP.pdf (81.38 Ko) Télécharger le fichier
inria-00439456 , version 1 (07-12-2009)
  • HAL Id : inria-00439456 , version 1
Bart Lamiroy, Jean-Philippe Ropers. Assessing Inductive Logic Programming Classification Quality by Image Synthesis. Eighth IAPR International Workshop on Graphics Recognition - IAPR-GREC 2009, University of La Rochelle, Jul 2009, La Rochelle, France. pp.344-352. ⟨inria-00439456⟩
118 Consultations
151 Téléchargements
