Well-posedness, stability and invariance results for a class of multivalued Lur'e dynamical systems - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Rapport (Rapport De Recherche) Année : 2009
This paper analyzes the existence and uniqueness issues in a class of multivalued Lur'e systems, where the multivalued part is represented as the subdifferential of some convex, proper, lower semicontinuous function. Through suitable transformations the system is recast into the framework of dynamic variational inequalities and the well-posedness (existence and uniqueness of solutions) is proved. Stability and invariance results are also studied, together with the property of continuous dependence on the initial conditions. The problem is motivated by practical applications in electrical circuits containing electronic devices with nonsmooth multivalued voltage/current characteristics, and by state observer design for multivalued systems.
RR-7158.pdf (392.73 Ko) Télécharger le fichier
inria-00442081 , version 1 (12-01-2010)
  • HAL Id : inria-00442081 , version 1
Bernard Brogliato, Daniel Goeleven. Well-posedness, stability and invariance results for a class of multivalued Lur'e dynamical systems. [Research Report] RR-7158, INRIA. 2009. ⟨inria-00442081⟩
482 Consultations
186 Téléchargements
