SAMPLE SIZE DETERMINATION USING ROC ANALYSIS - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Communication Dans Un Congrès Année : 2007
The paper presents a new method of sample size determination (SSD) based on performance evaluation of systems under study. The method builds upon previous work on Bayesian approach to nonparametric receiver operating characteristics (ROC) analysis with estimation of probability density functions and confidence intervals for parameters of ROC curve. Technical details of the method together with an illustration of its application to a real clinical example is given. The advantages of the method include ability to handle and comparemodels built using multidimentional, multimodal data, with no need for prior estimation of the effect size and variability. The disadvantages of the approach include high computational requirements, especially when the method of SSD deploys AUC as a measure of systems performance.
BHC-SAMPLE-SIZE-ROC-CIMED-2007.pdf (284.44 Ko) Télécharger le fichier
inria-00442370 , version 1 (21-12-2009)
  • HAL Id : inria-00442370 , version 1
Viktoriya Stalbovskaya, Brahim Hamadicharef, Emmanuel C. Ifeachor. SAMPLE SIZE DETERMINATION USING ROC ANALYSIS. 3rd International Conference on Computational Intelligence in Medicine and Healthcare (CIMED2007), Jul 2007, Plymouth, United Kingdom. ⟨inria-00442370⟩
233 Consultations
3604 Téléchargements
