Numerical solution of the Poisson equation over hypercubes using reduced Chebyshev polynomial bases
We describe how to use new reduced size polynomial approximations for the numerical solution of the Poisson equation over hypercubes. Our method is based on a non-standard Galerkin method which allows test functions which do not verify the boundary conditions. Numerical examples are given in dimensions up to 8.
