A Fault-Tolerant, Scalable, Low-Overhead Distributed Garbage Detection Protocol - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Communication Dans Un Congrès Année : 1991
Marc Shapiro
We present a protocol for the distributed detection of garbage in a distributed system subject to common failures such as lost and duplicated messages, network partition, dismounted disks, and process, site and disk crashes. The protocol uses only information local to each site, or exchanged between pairs of sites; no global mechanism is necessary. Overhead is low. The protocol is parallel and should scale to extremely large systems.
Mots clés
DGC_rds91.pdf (843.35 Ko) Télécharger le fichier
inria-00444615 , version 1 (07-01-2010)
Marc Shapiro. A Fault-Tolerant, Scalable, Low-Overhead Distributed Garbage Detection Protocol. Symposium on Reliable Distributed Sytems (SRDS), 1991, Pisa, Italy, Italy. pp.208--217, ⟨10.1109/RELDIS.1991.145426⟩. ⟨inria-00444615⟩
Collections
INRIA INRIA2
131 Consultations
334 Téléchargements
