Towards Safe Vehicle Navigation in Dynamic Urban Scenarios - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Automatika ‒ Journal for Control, Measurement, Electronics, Computing and Communications Année : 2009
This paper describes the deliberative part of a navigation architecture designed for safe vehicle navigation in dynamic urban environments. It comprises two key modules working together in a hierarchical fashion: (a) the Route Planner whose purpose is to compute a valid itinerary towards the a given goal. An itinerary comprises a geometric path augmented with additional information based on the structure of the environment considered and traffic regulations, and (b) the Partial Motion Planner whose purpose is to ensure the proper following of the itinerary while dealing with the moving objects present in the environment (eg other vehicles, pedestrians). In the architecture proposed, a special attention is paid to the motion safety issue, ie the ability to avoid collisions. Different safety levels are explored and their operational conditions are explicitly spelled out (something which is usually not done).
09-automatika-macek-etal.pdf (792.05 Ko) Télécharger le fichier
inria-00447452 , version 1 (15-01-2010)
  • HAL Id : inria-00447452 , version 1
Kristijan Macek, Dizan Alejandro Vasquez Govea, Thierry Fraichard, Roland Y. Siegwart. Towards Safe Vehicle Navigation in Dynamic Urban Scenarios. Automatika ‒ Journal for Control, Measurement, Electronics, Computing and Communications, 2009. ⟨inria-00447452⟩
561 Consultations
771 Téléchargements
