Efficient pricing options under regime switching - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Rapport (Rapport De Recherche) Année : 2010
Oleg Kudryavtsev
  • Fonction : Auteur
  • PersonId : 854863
In the paper, we propose two new efficient methods for pricing barrier option in wide classes of Lévy processes with/without regime switching. Both methods are based on the numerical Laplace transform inversion formulae and the Fast Wiener-Hopf factorization method developed in Kudryavtsev and Levendorski\v{i} (Finance Stoch. 13: 531--562, 2009). The first method uses the Gaver-Stehfest algorithm, the second one -- the Post-Widder formula. We prove the advantage of the new methods in terms of accuracy and convergence by using Monte-Carlo simulations.
RR-7184.pdf (356.63 Ko) Télécharger le fichier
inria-00450291 , version 1 (26-01-2010)
  • HAL Id : inria-00450291 , version 1
Oleg Kudryavtsev. Efficient pricing options under regime switching. [Research Report] RR-7184, INRIA. 2010, pp.35. ⟨inria-00450291⟩
260 Consultations
337 Téléchargements
