Approximate Shortest Paths Avoiding a Failed Vertex: Optimal Size Data Structures for Unweighted Graph - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Neelesh Khanna
  • Fonction : Auteur correspondant
  • PersonId : 867169
Connectez-vous pour contacter l'auteur
Surender Baswana
  • Fonction : Auteur
  • PersonId : 867170
Let $G=(V,E)$ be any undirected graph on $V$ vertices and $E$ edges. A path $\textbf{P}$ between any two vertices $u,v\in V$ is said to be $t$-approximate shortest path if its length is at most $t$ times the length of the shortest path between $u$ and $v$. We consider the problem of building a compact data structure for a given graph $G$ which is capable of answering the following query for any $u,v,z\in V$ and $t>1$: Report $t$-approximate shortest path between $u$ and $v$ when vertex $z$ fails We present data structures for the single source as well all-pairs versions of this problem. Our data structures guarantee optimal query time. Most impressive feature of our data structures is that their size {\em nearly} match the size of their best static counterparts.
khanna.pdf (240.06 Ko) Télécharger le fichier
inria-00455747 , version 1 (11-02-2010)
  • HAL Id : inria-00455747 , version 1
Neelesh Khanna, Surender Baswana. Approximate Shortest Paths Avoiding a Failed Vertex: Optimal Size Data Structures for Unweighted Graph. 27th International Symposium on Theoretical Aspects of Computer Science - STACS 2010, Inria Nancy Grand Est & Loria, Mar 2010, Nancy, France. pp.513-524. ⟨inria-00455747⟩
Collections
STACS2010
118 Consultations
367 Téléchargements
