Online Correlation Clustering - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
We study the online clustering problem where data items arrive in an online fashion. The algorithm maintains a clustering of data items into similarity classes. Upon arrival of v, the relation between v and previously arrived items is revealed, so that for each u we are told whether v is similar to u. The algorithm can create a new cluster for v and merge existing clusters. When the objective is to minimize disagreements between the clustering and the input, we prove that a natural greedy algorithm is O(n)-competitive, and this is optimal. When the objective is to maximize agreements between the clustering and the input, we prove that the greedy algorithm is .5-competitive; that no online algorithm can be better than .834-competitive; we prove that it is possible to get better than 1/2, by exhibiting a randomized algorithm with competitive ratio .5+c for a small positive fixed constant c.
mathieu.pdf (218.31 Ko) Télécharger le fichier
inria-00455771 , version 1 (11-02-2010)
  • HAL Id : inria-00455771 , version 1
Claire Mathieu, Ocan Sankur, Warren Schudy. Online Correlation Clustering. 27th International Symposium on Theoretical Aspects of Computer Science - STACS 2010, Inria Nancy Grand Est & Loria, Mar 2010, Nancy, France. pp.573-584. ⟨inria-00455771⟩
158 Consultations
206 Téléchargements
