AMS Without 4-Wise Independence on Product Domains - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
In their seminal work, Alon, Matias, and Szegedy introduced several sketching techniques, including showing that 4-wise independence is sufficient to obtain good approximations of the second frequency moment. In this work, we show that their sketching technique can be extended to product domains $[n]^k$ by using the product of 4-wise independent functions on $[n]$. Our work extends that of Indyk and McGregor, who showed the result for $k = 2$. Their primary motivation was the problem of identifying correlations in data streams. In their model, a stream of pairs $(i,j) \in [n]^2$ arrive, giving a joint distribution $(X,Y)$, and they find approximation algorithms for how close the joint distribution is to the product of the marginal distributions under various metrics, which naturally corresponds to how close $X$ and $Y$ are to being independent. By using our technique, we obtain a new result for the problem of approximating the $\ell_2$ distance between the joint distribution and the product of the marginal distributions for $k$-ary vectors, instead of just pairs, in a single pass. Our analysis gives a randomized algorithm that is a $(1 \pm \epsilon)$ approximation (with probability $1-\delta$) that requires space logarithmic in $n$ and $m$ and proportional to $3^k$.
braverman.pdf (181.97 Ko) Télécharger le fichier
inria-00455776 , version 1 (11-02-2010)
  • HAL Id : inria-00455776 , version 1
Vladimir Braverman, Kai-Min Chung, Zhenming Liu, Michael Mitzenmacher, Rafail Ostrovsky. AMS Without 4-Wise Independence on Product Domains. 27th International Symposium on Theoretical Aspects of Computer Science - STACS 2010, Inria Nancy Grand Est & Loria, Mar 2010, Nancy, France. pp.119-130. ⟨inria-00455776⟩
Collections
STACS2010
68 Consultations
136 Téléchargements
