Variance reduction in stochastic homogenization : proof of concept, using antithetic variables - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Rapport (Rapport De Recherche) Année : 2010
Réduction de variance en homogénéisation stochastique : l'exemple des variables antithétiques
We show that we can reduce the variance in a simple problem of stochastic homogenization using the classical technique of antithetic variables. The setting, and the presentation, are deliberately kept elementary. We point out the main issues, show some illustrative results, and demonstrate, both theoretically and numerically, the efficiency of the approach on simple cases.
RR-7207.pdf (282.27 Ko) Télécharger le fichier
inria-00457946 , version 1 (19-02-2010)
  • HAL Id : inria-00457946 , version 1
Ronan Costaouec, Claude Le Bris, Frédéric Legoll. Variance reduction in stochastic homogenization : proof of concept, using antithetic variables. [Research Report] RR-7207, Inria. 2010, pp.1-21. ⟨inria-00457946⟩
267 Consultations
172 Téléchargements
