Expression and Composition of Design Patterns with AspectJ - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Revue des Sciences et Technologies de l'Information - Série L'Objet : logiciel, bases de données, réseaux Année : 2006
Pierre Cointe
  • Fonction : Auteur
  • PersonId : 855473
Design patterns are well-known couples of problems-solutions for software engineer- ing. By nature, they often lack support from languages and this further complicates the study of their composition in the code. Aspect-oriented languages provide new mechanisms for modula- rization, which can help to improve design patterns implementation. (Hannemann et al., 2002) is the first extensive study of patterns aspectization with AspectJ. We notice some AspectJ idioms are needed in order to implement object relationships. We give a more reusable VISITOR pat- tern. We highlight a reusable composition of COMPOSITE and VISITOR patterns and expressive interactions of the OBSERVER pattern with a tree structure. We thus show that modularization by aspects helps composition of design patterns.
denier-lobjet06.pdf (187.5 Ko) Télécharger le fichier
inria-00458203 , version 1 (19-02-2010)
  • HAL Id : inria-00458203 , version 1
Simon Denier, Pierre Cointe. Expression and Composition of Design Patterns with AspectJ. Revue des Sciences et Technologies de l'Information - Série L'Objet : logiciel, bases de données, réseaux, 2006, 12 (2-3), pp.41-61. ⟨inria-00458203⟩
132 Consultations
518 Téléchargements
