Generating Synchronization Engines between Running Systems and Their Model-Based Views - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Communication Dans Un Congrès Année : 2009
Hui Song
  • Fonction : Auteur
  • PersonId : 867541
Yingfei Xiong
  • Fonction : Auteur
  • PersonId : 867542
Franck Chauvel
  • Fonction : Auteur
  • PersonId : 867540
Gang Huang
  • Fonction : Auteur
  • PersonId : 867543
Zhenjiang Hu
  • Fonction : Auteur
  • PersonId : 867544
The key point to leverage model-based techniques on runtime system management is to ensure the correct synchronization between the running system and its model-based view. In this paper, we present a generative approach, and the supporting tool, to make systematic the development of synchronization engines between running systems and models. We require developers to specify \what kinds of elements to manage" as a MOF meta-model and \how to manipulate those elements using the system's management API" as a so-called access model. From these two specications, our SM@RT tool automatically generates the synchronization engine to re ect the running system as a MOF-compliant model. We have applied this approach on several practical systems, in-cluding the JOnAS JEE server.
2-2009-MODELS-SM_RT.pdf (561.26 Ko) Télécharger le fichier
inria-00459616 , version 1 (24-02-2010)
  • HAL Id : inria-00459616 , version 1
Hui Song, Yingfei Xiong, Franck Chauvel, Gang Huang, Zhenjiang Hu, et al.. Generating Synchronization Engines between Running Systems and Their Model-Based Views. ACM/IEEE 12th International Conference on Model Driven Engineering Languages and Systems (MoDELS'09), Oct 2009, Denver, United States. ⟨inria-00459616⟩
Collections
CONNECT
451 Consultations
148 Téléchargements
