Dependability in dynamic, evolving and heterogeneous systems: the CONNECT approach - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
The EU Future and Emerging Technologies (FET) Project Connect aims at dropping the heterogeneity barriers that prevent the eternality of networking systems through a revolutionary approach: to synthesise on-the-y the Connectors via which networked systems communicate. The Connect approach, however, comes at risk from the standpoint of dependability, stressing the need for methods and tools that ensure resilience to faults, errors and malicious attacks of the dynamically Connected system. We are investigating a comprehensive approach, which combines dependability analysis, security enforcement and trust assessment, and is centred around a lightweight adaptive monitoring framework. In this project paper, we overview the research that we are undertaking towards this objective and propose a unifying workflow process that encompasses all the Connect dependability/security/trust concepts and models.
serene2010-camera-ready.pdf (582.34 Ko) Télécharger le fichier
inria-00465229 , version 1 (19-03-2010)
  • HAL Id : inria-00465229 , version 1
Antonia Bertolino, Felicita Di Giandomenico, Paolo Masci, Antonino Sabetta, Fabio Martinelli, et al.. Dependability in dynamic, evolving and heterogeneous systems: the CONNECT approach. SERENE 2010 - 2nd International Workshop on Software Engineering for Resilient Systems, ERCIM, Apr 2010, London, United Kingdom. ⟨inria-00465229⟩
503 Consultations
109 Téléchargements
