Improving Routing and Network Performance in Mobile Ad Hoc Networks Using Quality of Nodes - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Communication Dans Un Congrès Année : 2003
Navid Nikaein
  • Fonction : Auteur
  • PersonId : 868226
Christian Bonnet
In this paper we suggest a mechanism to describe the quality of nodes over time from the network point of view, and use this quality for extracting the links connecting the pair of best nodes. Therefore, links (or nodes) can be properly selected so as to improve the routing performance. We also present a distributed algorithm to construct a forest of nodes with the high quality. The constructed forest reduces the broadcasting overhead by selecting a subset of the neighboring nodes for forwarding a packet. Furthermore, the subset of the forwarding nodes belongs to the set of nodes with the high quality, which in turn improves routing performance. We also provide some simulation results to show the efficiency of the algorithm.
bonnet-improving.pdf (106.73 Ko) Télécharger le fichier
inria-00466593 , version 1 (24-03-2010)
  • HAL Id : inria-00466593 , version 1
Navid Nikaein, Christian Bonnet. Improving Routing and Network Performance in Mobile Ad Hoc Networks Using Quality of Nodes. WiOpt'03: Modeling and Optimization in Mobile, Ad Hoc and Wireless Networks, Mar 2003, Sophia Antipolis, France. 5 p. ⟨inria-00466593⟩
73 Consultations
74 Téléchargements
