Efficient implementation of interval matrix multiplication - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Hong Diep Nguyen
  • Fonction : Auteur correspondant
  • PersonId : 868508
Connectez-vous pour contacter l'auteur
The straightforward implementation of interval matrix product suf- fers from poor efficiency, far from the performances of highly optimized floating-point implementations. In this paper, we show how to reduce the interval matrix multiplication to 9 floating-point matrix products - for performance issues - without sacrificing the quality of the result. We show that, compared to the straightforward implementation, the overes- timation factor is at most 1.18.
NGUYEN_mat_prod.pdf (114.57 Ko) Télécharger le fichier
inria-00469472 , version 1 (01-04-2010)
  • HAL Id : inria-00469472 , version 1
Hong Diep Nguyen. Efficient implementation of interval matrix multiplication. Para 2010: State of the Art in Scientific and Parallel Computing, Jun 2010, Reykjavik, Iceland. ⟨inria-00469472⟩
131 Consultations
1588 Téléchargements
