BBOB 2009: Comparison Tables of All Algorithms on All Noisy Functions - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Rapport (Rapport Technique) Année : 2010
Anne Auger
  • Fonction : Auteur
  • PersonId : 751513
  • IdHAL : anne-auger
Nikolaus Hansen
Raymond Ros
  • Fonction : Auteur
  • PersonId : 868664
This document presents the results in the form of tables from the Black-Box Optimization Benchmarking (BBOB) workshop of the Genetic and Evolutionary Computation Conference (GECCO), Montreal Canada, 2009. Each table presents the comparative performances of the algorithms submitted to BBOB 2009 on one problem from the noisy function testbed.
RT-0384.pdf (1.94 Mo) Télécharger le fichier
inria-00471253 , version 1 (07-04-2010)
inria-00471253 , version 2 (13-04-2010)
  • HAL Id : inria-00471253 , version 2
Anne Auger, Steffen Finck, Nikolaus Hansen, Raymond Ros. BBOB 2009: Comparison Tables of All Algorithms on All Noisy Functions. [Technical Report] RT-0384, INRIA. 2010. ⟨inria-00471253v2⟩
217 Consultations
831 Téléchargements
