A Synthesis on Partition Refinement: a Usefull Routine for Strings, Graphs, Boolean Matrices and Automata - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Communication Dans Un Congrès Année : 1998
Partition refinement techniques are used in many algorithms. This tool allows efficient computation of equivalence relations and is somehow dual to union-find algorithms. The goal of this paper is to propose a single routine to quickly implement all these already known algorithms and to solve a large class of potentially new problems. Our framework yields to a unique scheme for correctness proofs and complexity analysis. Various examples are presented to show the different ways of using this routine.
stacs98.pdf (219.35 Ko) Télécharger le fichier
inria-00471611 , version 1 (08-04-2010)
Michel Habib, Christophe Paul, Laurent Viennot. A Synthesis on Partition Refinement: a Usefull Routine for Strings, Graphs, Boolean Matrices and Automata. STACS: Symposium on Theoretical Aspects of Computer Science, Feb 1998, Paris, France. pp.25-38, ⟨10.1007/BFb0028546⟩. ⟨inria-00471611⟩
199 Consultations
415 Téléchargements
