Optimized Link State Routing Protocol (OLSR) - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Autre Publication Année : 2003
Thomas Clausen
Philippe Jacquet
Cédric Adjih
Pascale Minet
Paul Mühlethaler
  • Fonction : Auteur
  • PersonId : 833453
Laurent Viennot
This document describes the Optimized Link State Routing (OLSR) protocol for mobile ad hoc networks. The protocol is an optimization of the classical link state algorithm tailored to the requirements of a mobile wireless LAN. The key concept used in the protocol is that of multipoint relays (MPRs). MPRs are selected nodes which forward broadcast messages during the flooding process. This technique substantially reduces the message overhead as compared to a classical flooding mechanism, where every node retransmits each message when it receives the first copy of the message. In OLSR, link state information is generated only by nodes elected as MPRs. Thus, a second optimization is achieved by minimizing the number of control messages flooded in the network. As a third optimization, an MPR node may chose to report only links between itself and its MPR selectors. Hence, as contrary to the classic link state algorithm, partial link state information is distributed in the network. This information is then used for route calculation. OLSR provides optimal routes (in terms of number of hops). The protocol is particularly suitable for large and dense networks as the technique of MPRs works well in this context.
5145.pdf (408.95 Ko) Télécharger le fichier
inria-00471712 , version 1 (08-04-2010)
  • HAL Id : inria-00471712 , version 1
Thomas Clausen, Philippe Jacquet, Cédric Adjih, Anis Laouiti, Pascale Minet, et al.. Optimized Link State Routing Protocol (OLSR). 2003. ⟨inria-00471712⟩
6020 Consultations
3394 Téléchargements
