A Self-Adaptable Approach for Easing the Development of Grid-Oriented Services - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
The Service-Oriented Architecture (SOA) leverages the service abstraction to enable the development of modular, loose-coupled and distributed applications. In order to use such an architecture, service-based applications directly rely on services or compose them for conceiving new functionalities. In spite of these capabilities, they do not support the development of services which need high-performance computing. Grid computing offers an infrastructure for high-performance computing which is based on the sharing of distributed, low-cost and heterogeneous resources in large-scale. Thus, grids can be used to satisfy these high-performance service requirements. This work aims at easing the development of grid-oriented services. The iPOJO service-component model is used to propose an architecture that automatically manages job submission for services. This architecture is based on Dynaco (Adaptation for Components) and the XtreemOS grid operating system.
lage-pazat-CIT-2010.pdf (603.66 Ko) Télécharger le fichier
inria-00474992 , version 1 (01-07-2010)
André Lage Freitas, Jean-Louis Pazat. A Self-Adaptable Approach for Easing the Development of Grid-Oriented Services. International Conference on Computer and Information Technology (CIT 2010), Jun 2010, Bradford, United Kingdom. ⟨10.1109/CIT.2010.56⟩. ⟨inria-00474992⟩
166 Consultations
216 Téléchargements
