New analysis of the asymptotic behavior of the Lempel-Ziv compression algorithm - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Rapport (Rapport De Recherche) Année : 2010
We give a new analysis and proof of the Normal limiting distribution of the number of phrases in the 1978 Lempel-Ziv compression algorithm on random sequences built from a memoriless source. This work is a follow-up of our last paper on this subject in 1995. The analysis stands on the asymptotic behavior of a DST obtained by the insertion of random sequences. Our proofs are augmented of new results on moment convergence, moderate and large deviations, redundancy analysis.
LZ-RR.pdf (228.07 Ko) Télécharger le fichier
inria-00476902 , version 1 (27-04-2010)
  • HAL Id : inria-00476902 , version 1
Philippe Jacquet, Szpankowski Wojciech. New analysis of the asymptotic behavior of the Lempel-Ziv compression algorithm. [Research Report] 2010. ⟨inria-00476902⟩
182 Consultations
41 Téléchargements
